Banjo people?
Banjo people?
Post by Dave Bagwill » Wed Jun 15, 2016 11:56 am
A friend brought over a 6 -string banjo, an inexpensive one, that has a bridge that is dimpling the top; in fact at the bridge the top is at least 1/4" lower than the rim.
I know nothing 'bout banjos - though this one is kind fun - but I'm sure it would perform better if the top was right. Is there an easy adjustment, or is this a major problem?
Thanks
Re: Banjo people?
Post by ken cierp » Wed Jun 15, 2016 2:03 pm
You need to tighten and tune the skin --- not difficult but requires using a pattern and torque/tension specs.
Re: Banjo people?
Post by Dave Bagwill » Wed Jun 15, 2016 2:04 pm
Thanks.
Re: Banjo people?
Post by Tim Benware » Wed Jun 15, 2016 5:05 pm
I tune banjos to the G#3. You should have 1/4 nuts on the hooks and can use a 1/4" drive to tighten the head. There are 24 hooks on that banjo and to tune it go clockwise starting with the hook nearest the neck on the right side and number that "#1." Then you will tighten 1, 13, 2, 14, 3, 15, 4 (get the pattern).
If the head is really loose you may want to start by just going around the head in order until there is a little tension on each of the hooks then start into the pattern turning each nut a quarter to a half turn, this will get progressively less as you close in on the G#3 note. Tune the head with the tension off the strings. I use a piano striker (that has been cut down) to tap the head about a 1/2 to 3/4" in front of each hook until I reach the G#3. The tapped note should sound the same in front of each hook and that tells you the head is tightened evenly. You can a something of similar weight to the piano striker to tap.
Re: Banjo people?
Post by Dave Bagwill » Wed Jun 15, 2016 5:36 pm
Okey-dokey, will try that, thanks Tim.
ARe you sure I can't just keep it in the fridge and then let it come to room temperature? Hahahahahahaha...
Re: Banjo people?
Post by Tim Benware » Wed Jun 15, 2016 9:53 pm
I've tried everything I can think of to make those things sound better, maybe that would work:)
