Number nine is underway
While the finish cures on my 00 cutaway, I've started on number nine. I've found that I really enjoy playing my Cherry Norman Blake style OM so I've decide to do this guitar along the same lines. It will be a 00 size 12 fret a la Norman Blake. I'll use the 14 fret body shape and move the sound hole and bracing down accordingly. It will be Narra and Engleman Spruce.
- image.jpeg (67.67 KiB) Viewed 1431 times
- image.jpeg (96.08 KiB) Viewed 1431 times
- Pre-bent waists
- image.jpeg (76.07 KiB) Viewed 1431 times
- Bending sandwich. This stuff bends like a dream.
- image.jpeg (97.65 KiB) Viewed 1431 times
- image.jpeg (91.38 KiB) Viewed 1431 times
- Mega Mold Land
- image.jpeg (67.01 KiB) Viewed 1431 times
JJ
Re: Number nine is underway
John,
That narra is beautiful. Can't wait to see it under finish. I'm curious about your bending pipe set up. I need to upgrade my black pipe and propane torch bender. Can you tell me a little about it and a couple pics? PM if you prefer. Thanks.
Rosette. This one is Amboyna burl and BRW with maple strips. I found out after I did this one that the Amboyna burl grows on the Narra tree
- image.jpeg (103.16 KiB) Viewed 1409 times
- image.jpeg (105.34 KiB) Viewed 1409 times
- image.jpeg (124.14 KiB) Viewed 1409 times
JJ
The wood is beautiful, and the rosette is really nice too. Going to be nice.
Coming along. Top bracing a little more thin at the top than I've done before. Closed up and rebates cut. Mahogany neck roughed out and fitted.
- image.jpeg (123.17 KiB) Viewed 1361 times
- image.jpeg (129.49 KiB) Viewed 1361 times
- image.jpeg (131.56 KiB) Viewed 1361 times
- image.jpeg (132.7 KiB) Viewed 1361 times
- image.jpeg (111.25 KiB) Viewed 1361 times
- image.jpeg (122.94 KiB) Viewed 1361 times
- image.jpeg (104.35 KiB) Viewed 1361 times
- image.jpeg (129.96 KiB) Viewed 1361 times
JJ
The build is moving along; really clean work. The narra really is good looking wood. Great looking rosette.
Moving along. Box awaits final sanding while I finish the neck. Cut my inlays and hope to get them in this weekend. The Narra is really beautiful. Can't wait to see it with a finish on it.
- image.jpeg (80.2 KiB) Viewed 1329 times
- image.jpeg (78.72 KiB) Viewed 1329 times
- image.jpeg (125.11 KiB) Viewed 1329 times
- image.jpeg (180.8 KiB) Viewed 1329 times
JJ
