Found it in the shop, don't remember seeing it before. It is for the Dremel, apparently.
Boy, does the skin on my leg look bad..
Can you I.D. this bit?
- DSC01697.JPG (175.07 KiB) Viewed 1773 times
Re: Can you I.D. this bit?
It's a drywall cutting bit for the dremel.
"Roto-Tool" zip bit
[quote=Boy, does the skin on my leg look bad..[/quote]
You sir, are one leathery character.
I'm sure there's an ointment, balm, or salve that you could find on amazon... although I hear that hot hide glue does wonders!
Take more than that - this is a result of an old gypsy woman's curse - I had laughed at her because she only had the one tooth, and the word 'hag' may have slipped out; in any case, leather leg is what I have, and it is moving up my body.
Yes, you understand my concern.
I'll be needing some Johnson and JOhnson ointment pretty soon...
Mom says that won't work, nothing will. You should have been friendlier to her when you had the chance.
