Would this work?
Would this work?
Post by Dave Bagwill » Thu Apr 07, 2016 6:39 pm
This measures the thickness of non-metallic coatings, like on cars.
Up to 2 mm.
Would it work measuring the thickness of wood, if you held a magnetic material against the top on the inside?
http://www.amazon.com/AGPtek%C2%AE-Digi ... B00IG0MEUA
Re: Would this work?
Post by John Parchem » Thu Apr 07, 2016 6:45 pm
The meter most likely measures the distance it is from the metal panel. Putting something inside the guitar would not give you a relevant reading.
Post by Dave Bagwill » Thu Apr 07, 2016 6:49 pm
A piece of metal that could be detected by the magnet wouldn't work? Dang.
Post by John Parchem » Fri Apr 08, 2016 4:07 am
actually up to 2mm it would measure the wood. My apology I though you wanted to measure your finish.
Post by ken cierp » Fri Apr 08, 2016 9:09 am
If you could find one that measures thicker, like 4mm you could have a check point where you know exactly how thick the wood is, then place a metal plate in that location. Take the measurement minus the known wood thickness = paint thickness.
Much hassle -- I simply guess, leaning toward applying too much
