vacuum clamp for bridges
Post by Dave Bagwill » Fri Mar 11, 2016 2:44 am
I used a vacuum clamp for gluing on a couple of bridges, and each time I did, the footprint of the clamp left an impression on the finish that was difficult to rub out.
Has anyone else had that problem, or know of a way to mitigate it?
Re: vacuum clamp for bridges
Post by ken cierp » Fri Mar 11, 2016 8:38 am
Your parameters -- finish, timing, method etc.?
Post by John Parchem » Fri Mar 11, 2016 9:50 am
I use the LMI clamp it on almost all the guitars I make and I use a home made one on ukuleles. I used mostly EM6000 or Shellac as a top coat. I had contaminates on the foam gasket once that left a mark. Otherwise no problems.
