One picture to show the challenge.
Suggestions for a 'like it never happened' fix?
This is Tom's guitar and he's done a great job, but we need to address this. I know it's been talked about before but in case there is a new approach....
Unfortunate gappage
Unfortunate gappage
- DSC01643.JPG (79.02 KiB) Viewed 4061 times
Re: Unfortunate gappage
Heat and tape
It looks like the waist so I would use heat and a quick grip bar clamp fitted with a waist matching caul. I use one as part of my normal binding glue up. PVA is actually thermoplastic so it will soften and re-cure.
Sorry I was not clear - this is the rosette, and the filling of the gap is my concern - past reading leads me to believe that dust is not a solution? Or is dust mixed with shellac or lacquer a good way to go?
Gap filling light wood will still look like -- well, like it looks now not good, pulling it in tight is what I would try to do. And honesty if the did not work, this is such a focal point I'd have to redo.
I cannot explain the gap, it was not apparent when we glued in the rosette, but now the body is about completed so I see no way to realistically start over.
Odd things do happen.
If the trim was made of wood or fiber perhaps the glue caused it to expand and when it dried a little shrinkage?
Anyway -- I have successfully pulled in binding and/or purfling gaps with little heat and tape.
