3-piece neck wood dimensions
Post by peter havriluk » Sat Dec 19, 2015 6:27 pm
I have in my stash of parts purchased when I knew too little for my own good a pair of black cherry necks whose fretboard areas are 3/4" thick. Seems a mite skimpy, as wood vendors seem to sell neck blanks cut from '1x3' stock. Is this really one inch by three inches or lumberyard terms for materials measuring 3/4" x 2 1/2"? And is it a rational idea to use material 3/4" thick for an acoustic neck? The only advice I've found encourages the builder to 'make the neck blank 1/64" thicker than the finished neck thickness'. If only I knew what that was. I was planning on carving until I had something that either felt good or felt familiar, at least.
Thanks, folks.
Re: 3-piece neck wood dimensions
Post by ken cierp » Mon Dec 21, 2015 11:30 am
I know its not my $$ (Cherry is not expensive) but unless the wood is special or has special meaning I would not mess with it for necks -- yes 1/4" sawn blanks are usually minimum of 7/8" x 3 1/2" wide so the blended heel stack looks OK.
Post by peter havriluk » Mon Dec 21, 2015 3:42 pm
Ken, thanks for taking the time to offer some advice. Which I'm taking. I can chew on stuff that looks like a neck all I want, but I'll get indigestion. Well past time to use the necks as 3D models of necks and make some out of safer materials. Cheap tuition at the school of experience.
