Number six for me. I was planning to use a black limba back and side set I had for this one, but scrapped that after my sides cracked across the grain while pre bending the waist. So this will be a cherry and Engleman spruce guitar. The cherry bends wonderfully, however I had a small goof in marking the waist when I bent the sides. I ended up with a gap at the neck block. With forum advice I adjusted the mega mold (it is a wonderful tool, Ken!) and made the upper bout a little smaller. Overall length is shortened by 1/2". I decided to leave the bracing and sound hole as is and lengthen the bridge plate the 1/2". Tim is together and I'm working on the top bracing.
I like to keep doing these construction logs for myself and especially for newcomers to this craft. I know the have helped me immensely.
A Norman Blake style OM
- Cherry back glue up. It's got some wonderful figure.
- image.jpeg (133.96 KiB) Viewed 1042 times
- Another bending mold completed.
- image.jpeg (76.06 KiB) Viewed 1042 times
- My bad.
- image.jpeg (128.7 KiB) Viewed 1042 times
- Showing how much I'll need to adjust the mega mold.
- image.jpeg (131.19 KiB) Viewed 1042 times
- Pre bending the linings.
- image.jpeg (159.34 KiB) Viewed 1042 times
- Linings installed.
- image.jpeg (95.29 KiB) Viewed 1042 times
- Side bracing.
- image.jpeg (99.52 KiB) Viewed 1042 times
- image.jpeg (73.26 KiB) Viewed 1042 times
- Tamarind rosette.
- image.jpeg (57.15 KiB) Viewed 1042 times
- Clamping the bridge plate. They look a little like turtles,no?
- image.jpeg (62.65 KiB) Viewed 1042 times
JJ
Re: A Norman Blake style OM
Excellent photos John. Thanks for sharing your work.
In the "Getting ahead of yourself department " it seems as if I'm knee deep in it on this project. I set the neck slope for the top with Ken's directions on the mega mold, got my top fitted and went ahead and glued it on. Guess what I forgot to do? Yup, I didn't contour the back rim (insert a head slap and a loud "Doh!" here). So I trimmed the top and I'll contour with my bar from the success kit from my first guitar. Just when you think you know what you're doing it turns out you don't.i
- image.jpeg (215.22 KiB) Viewed 997 times
JJ
Got the box closed up and the sides sanded and ready for cutting the rebates. Bound the fretboard in cherry. I used ca glue and accidentally partially filled three feet slots. Thankfully I was able to soften the ca glue with Goof Off super glue remover and carefully pick the slots clean. I made a handle for my radius block (per Ken's suggestion-makes it much easier!). I made it so I can transfer the handle to a different block if needed. I have my neck roughed out and the tenon cut.
- When you need to stretch that rubber band!
- image.jpeg (149.11 KiB) Viewed 954 times
- image.jpeg (130.98 KiB) Viewed 954 times
- image.jpeg (100.78 KiB) Viewed 954 times
- image.jpeg (154.7 KiB) Viewed 954 times
- image.jpeg (124.09 KiB) Viewed 954 times
- image.jpeg (103.64 KiB) Viewed 954 times
JJ
Bindings (leopardwood) done and body sanded to 180. Using gold mop for the inlays on this one. I'm getting more proficient with each inlay. I bought a foot switch for the dremel and it makes it so much easier. Not worried about jostling the bit when I turn the tool off. I used brown tinted epoxy on the Katalox board.
- image.jpeg (47.28 KiB) Viewed 879 times
- image.jpeg (109.21 KiB) Viewed 879 times
- image.jpeg (124.5 KiB) Viewed 879 times
- image.jpeg (83.8 KiB) Viewed 879 times
- image.jpeg (51.08 KiB) Viewed 879 times
- image.jpeg (121.86 KiB) Viewed 879 times
- image.jpeg (128.18 KiB) Viewed 879 times
JJ
