Here I am using my rosette channel cutting tool.
David L
Rosette tool
Re: Rosette tool
David - what kind of bit are you using in that Dremel?
Re: Rosette tool
I am using a 3/32" downcut carbide. I figured what my OD was and kept shortening the ID of the cut little by little until I reached the desired width of the groove.
David L
David L
Re: Rosette tool
I just ordered the same router base and circle cutter jig. Do youDavid L wrote:I am using a 3/32" downcut carbide. I figured what my OD was and kept shortening the ID of the cut little by little until I reached the desired width of the groove.
David L
think using the 3/32 bit is a good one to start with? This will be
my first rosette. i'm just doing a 3mm abalone ring. I also
plan on practicing with mdf.
Any advice?
Re: Rosette tool
Re: Rosette tool
I will definitely get the down cut spiral bit. I think Rockler and Woodcraft have them.kencierp wrote:Down spiral you will not be sorry!
Here's the base fixture knock off
viewtopic.php?f=7&t=15
Re: Rosette tool
We get ours from here:
https://www.drillbitcity.com/catalogue/ ... _tools.asp
I believe they sell single bits as well
