Spanish cedar for a neck block?
John J
Post by John J » Sun Sep 06, 2015 7:58 pm
Working on my first neck from scratch and I made a bolt on neck block from Spanish cedar. Will it be strong enough or should I go with mahogany?
JJ
Re: Spanish cedar for a neck block?
Post by ken cierp » Sun Sep 06, 2015 10:25 pm
Spanish Cedar should work fine as long as you use a good size washer under the bole head and the wood is flat sawn. Many factories/makers including Martin even have models with Spanish Cedar necks.
Post by Dave Bagwill » Mon Sep 07, 2015 10:26 am
And correct that toe-in at the lower corner. :-)
John J
Post by John J » Mon Sep 07, 2015 1:23 pm
Dave Bagwill wrote:And correct that toe-in at the lower corner. :-)
At least it's not in focus!
JJ
Post by John Link » Mon Sep 07, 2015 1:24 pm
Working barefoot is typical of all the great luthiers.
Post by John Link » Mon Sep 07, 2015 1:26 pm
To go to your question about strength: Michael Collins designates spruce blocks in his plans for Maccaferri builds. These are 16 inch guitars, too. Spruce is, of course, not a dense wood.
