Another drum sander.
John J
Post by John J » Sat May 16, 2015 10:23 pm
I built this drum sander based on a free plan found on the web. Works great. Plenty of power and actually very little dust. I thinned down a practice side no problem.
Drum glued up.
Drum glued up.
Dust hood.
Dust hood.
Leveling the drum.
Leveling the drum.
JJ
John J
Re: Another drum sander.
Post by John J » Sat May 16, 2015 10:25 pm
More pictures.
Drum trued.
Drum trued.
80 grit hook n loop.
JJ
Post by Kevin in California » Sun May 17, 2015 9:52 pm
John that is sweet. I like the Velcro paper. I have wondered if there would be too much "cushion" from that though. No problems?
John J
Post by John J » Sun May 17, 2015 10:05 pm
I've only sanded down an orphan side of mahogany. It came out to a nice and even thickness to about .076" from .110". Lots of light passes versus trying to force it. So far so good.
JJ
Post by John Parchem » Mon May 18, 2015 12:56 am
Cool, that will be a useful home built tool.
Brad Hall
Post by Brad Hall » Fri Apr 01, 2016 2:07 am
I'm gathering parts to build this sander. I have the 1" shaft and the pillow block bearings. I'll be using 36" long shaft because of limited space. Should be wide enough for 2 back plates. What diameter pulleys are you using for shaft and motor? Where do you source the Velcro sandpaper and backing? Did you use the the same table tilt adjustment screw system shown on the plans? I will incorporate your sled. Any tips appreciated. Thanks.
John J
Post by John J » Fri Apr 01, 2016 10:01 am
Brad Hall wrote:I'm gathering parts to build this sander. I have the 1" shaft and the pillow block bearings. I'll be using 36" long shaft because of limited space. Should be wide enough for 2 back plates. What diameter pulleys are you using for shaft and motor? Where do you source the Velcro sandpaper and backing? Did you use the the same table tilt adjustment screw system shown on the plans? I will incorporate your sled. Any tips appreciated. Thanks.
Hi Brad
I'll pm you the details. (not supposed to link to suppliers I think)
Here's a couple of shots of the tilt bolt.
Make sure you make and use the dust hood! Mine is hooked up to my massive dust collection system. Well it's just an old craftsman shop vac with a dust deputy in-line. But it helps with the ever present wood dust problem. Good luck.
JJ
