Woodslicer / KerfMaster Bandsaw blades
Daniel P
Post by Daniel P » Thu Apr 16, 2015 1:08 am
I'm ready to upgrade the old used / rusty blade on my bandsaw and have had several recommendations for the Wood Slicer from Highland Woodworking. I've ready many great reviews as well.
Further research suggests that the Lenox KERFMaster, from Spectrum Supply, is the same Atlanta Sharptech blade stock.
They appear to have the same dimensional specs.
1/2 x .022 3/4 Variable tooth
3/4 x .022 3/4 Variable tooth
http://www.spectrumsupply.com/kerfmaster-2.aspx
Have any of you had first hand experience with the KERFMaster?
Re: Woodslicer / KerfMaster Bandsaw blades
Post by ken cierp » Thu Apr 16, 2015 8:53 am
The cutting tips on the Woodslicer appear to have additional processing -- hardening? Don't know? But I'd check that out for a true comparison. $17 for a 105" is a pretty good deal. I'll likely give a couple a try. Thanks
Post by Tim Benware » Thu Apr 16, 2015 9:15 am
ken cierp wrote:The cutting tips on the Woodslicer appear to have additional processing -- hardening?
They do and I suspect that may be the difference in price but don't know how that may equate to cut. I use the wood slicer and it works great. Tempted to try the other though myself.
Daniel P
Post by Daniel P » Thu Apr 16, 2015 10:40 am
I'll ask them about the hardened tips.
Looks like they get you on shipping though.
Daniel P
Post by Daniel P » Thu Apr 16, 2015 10:50 am
They do mention "After the teeth are set, the blade goes into a hardening process which makes the teeth last longer, even at sub-zero temperatures." They don't state a specific Rc Hardness as Highland does for the Wood Slicer ( 65-67).
I'll let you know what I hear back.
ken cierp wrote:The cutting tips on the Woodslicer appear to have additional processing -- hardening? Don't know? But I'd check that out for a true comparison. $17 for a 105" is a pretty good deal. I'll likely give a couple a try. Thanks
Post by Kevin in California » Thu Apr 16, 2015 12:37 pm
I've been having great success with the Woodslicer 1/2" on my Steel City saw. Resawn 10" tall Sapele, maple, walnut, cherry..has done a superb job
