1/4" , 1/2" shank router bits - - - differences, preferences
Post by peter havriluk » Thu Mar 26, 2015 10:47 pm
I'm thinking of buying an assortment of router bits from MLCS. I suspect it's less costly out of pocket to have a set on hand to choose from as opposed to making road trips to a vendor for one bit at a time. So, these folks offer their router bits in 1/2" shank and 1/4" shank versions for the same price. Seeing as I have two general-purpose routers, one with a 1/4" chuck, the other with a 1/2" chuck, is one shank size preferred?
Bob Matthews
Re: 1/4" , 1/2" shank router bits - - - differences, prefere
Post by Bob Matthews » Fri Mar 27, 2015 5:45 am
The 1/2" cutters will be far more sturdy, will vibrate less and will plough off material at an alarming rate. You will be amazed at the difference between the two machines and cutters doing the same job in cutting deep rebates, slots, mortices, channels, mouldings etc.
Having said that, I only use my 1/2" router for joinery work, like making windows, doors and furniture, I have never once used it on a guitar apart from routing out the body shape on solid bodied electric guitars.
A 1/2" router for general acoustic guitar construction is over kill imo.
Post by ken cierp » Fri Mar 27, 2015 7:49 am
Only buy what you actually need to do the task at hand and be selective to insure you have the correct bits. 1/4" shank work fine for the machining operations generally performed in a guitar shop.
Post by Tim Benware » Fri Mar 27, 2015 8:43 am
Although I use a 1/4" shank to rout the mortise and tenons (both straight and DT), I think I might prefer a 1/2 shank for that job. I don't know why, just think I would if I tried it.
Post by ken cierp » Fri Mar 27, 2015 9:14 am
Do they make/sell 1/2" shank bits with a bearing that will work with the standard design MT and DT templates?
Post by peter havriluk » Fri Mar 27, 2015 9:20 am
Thanks, folks, for the advice, experience, perspective. I need all three.
Post by Tim Benware » Fri Mar 27, 2015 12:07 pm
ken cierp wrote:Do they make/sell 1/2" shank bits with a bearing that will work with the standard design MT and DT templates?
Good question. Maybe that's why I'm not using them!
