I was gifted with one of Ken's bridge setter tools, for a 'standard' Martin scale length of 25.4". For my first neck project, I was planning on using a short scale fretboard made from a fretboard I'd already made for 25.4" and removing the first fret. Instant short scale of 23.974", close enough to the close-to-24-inches I had in mind. So...with appropriate precautions I think I can use the bridge setter tool to locate the short scale fretboard. Am I being over-optimistic?
Related question: I have a neck, all glued up, not shaped, that was formed to support a 25.4" scale length. I am considering using the neck for my short-scale fretboard by running it through a table saw to remove the stacked heel and to then reattach it to allow for a 14-fret neck, moving the stacked heel 1.426" (the distance between the original fretboard nut and first fret) farther forward, shortening the neck by that amount. I can restore the heel height by creative heel cap fabrication. Same question about optimism.
Thanks, folks.
Bridge setter tool - - - adapt to short scale
Re: Bridge setter tool - - - adapt to short scale
I guess that it would have to be measured ; my first thought was that the tool will fit over the wrong frets with your new scale length and that it would put the bridge in the wrong position by a lot. I do see where you are coming from though it would be like a capo on the first position, so the bridge should be set correctly as you surmised.I can use the bridge setter tool to locate the short scale fretboard. Am I being over-optimistic?
Reworking your neck could work OK, In the long term it seems like you may save time by keeping your current neck for a project using the 25.4 scale and making a new neck blank.
Thanks for taking the time and going to the trouble of a reply. Much obliged.
The neck...I can't see a use for it at full length on the horizon, and in that sense I'm willing to spend a couple of hours up close and personal with my buddy's wood shop modifying the neck. I might learn something and I'm not out much cash if I'm not successful. Whether that's a good use for time, I don't know. Cheap enough in money, perhaps expensive in time, but in terms of task, it's a one-time skill. Ambiguous, but my curiosity is aroused.
