Trend router
Trend router
Any one have or used this router? I was thinking of trying it for rosettes mainly cuz of the plunging capability which seemed it would have been nice to have that last time I did one which was my first. I do have a larger plunge router but maybe too big for rosettes. I've seen some bad and good reviews!
- image.jpg (122.71 KiB) Viewed 1349 times
Re: Trend router
Take a look at the Rigid at Home Depot
Re: Trend router
Excellent router! I own one and I'm thinking about buying another one to permanently mount on an edge binding router setup. At $99.00, it is a great buy.ken cierp wrote:Take a look at the Rigid at Home Depot
Re: Trend router
Jim were you talkin about the trend or the ridged router. I do have the ridged router which I use for trimming sides and truss rod. But I need a plunge for the rosette.
Re: Trend router
Why would you need a plunge router to cut rosette channels? Seems to me that would make the job more complicated.
Re: Trend router
Well it seems it would be easier to lower it down to the depth instead of pushing/guiding it down by hand/feel. How do you do yours Ken?. Before you had cnc if that's what your using now.
Re: Trend router
I liked the control one has when using the small footprint Dremel tool with the optional router base, the base also has a rack and pinion for fine height adjustment. I attached it to one of these
viewtopic.php?f=7&t=15
I always worked a sample (scrap) and the project at the same time to assure proper depths.
Yes those are days gone by -- we use CNC machines now.
