An HD-28 style for Tom T
Post by Tim Benware » Wed Dec 10, 2014 11:53 am
Thought I'd blog this build for my latest commission. The top is Adirondack, B/S are EIR, mahogany neck block with an M&T joint.
1 Jointing the Top (640x480).jpg (248.24 KiB) Viewed 1203 times
2 Top Glueup (640x480).jpg (240.66 KiB) Viewed 1203 times
3 Side Bending.jpg (303.79 KiB) Viewed 1203 times
4 In the Mold.jpg (281.29 KiB) Viewed 1203 times
5 Neck Block Glue Up.jpg (291.58 KiB) Viewed 1203 times
Re: An HD-28 style for Tom T
Post by Tim Benware » Wed Dec 10, 2014 11:59 am
The rosette is herringbone with multiple outside ring (no inner ring), the back has a zipper strip and the bracing is Adirondack. I used Ken's profiling jig to do the braces. Wish i had taken a pic but I profile these a while back. It is my first attempt using the jig and they came out real nice.
9 Back Spline Glue Up.jpg (260.05 KiB) Viewed 1200 times
6 Rosette Installed.jpg (239.34 KiB) Viewed 1201 times
7 Back Glue up.jpg (304 KiB) Viewed 1201 times
8 Back.jpg (287.54 KiB) Viewed 1201 times
10 X Brace Glue Up.jpg (314.99 KiB) Viewed 1201 times
Post by Tim Benware » Wed Dec 10, 2014 12:05 pm
It will have curly maple binding and herringbone purfling. The braces are positioned for glue up.
11 Binding Bent.jpg (289.09 KiB) Viewed 1200 times
12 Binding and Purfling.jpg (271.02 KiB) Viewed 1200 times
13 Back Braces.jpg (285.57 KiB) Viewed 1200 times
14 Back Braces Ready for Glue Up.jpg (295.68 KiB) Viewed 1200 times
15 Top Braces Ready for Glue Up.jpg (240.83 KiB) Viewed 1200 times
Post by Herman » Wed Dec 10, 2014 1:08 pm
Tim, you are saving me a lot of time at posting.I'm about to start exactly the same build.
So no blog from me. We better call this the Tim/Herman blog.:-)
Post by Tim Benware » Wed Dec 10, 2014 6:06 pm
Herman wrote:Tim, you are saving me a lot of time at posting.I'm about to start exactly the same build.
Go for it. It's always interesting to see other processes and similarities and differences.
Post by Tim Benware » Wed Dec 10, 2014 6:08 pm
Got the top and back braces glued on and started carving the top braces. I use a vacuum bag for brace glue up.
16 Top Brace Glue Up.jpg (245.09 KiB) Viewed 1183 times
17 Ready for Carving.jpg (231.01 KiB) Viewed 1183 times
Post by Tim Benware » Wed Dec 17, 2014 10:34 am
Continued progress.
18 Braces Scalloped.jpg (269.62 KiB) Viewed 1149 times
19 Installing Kerfing.jpg (307.86 KiB) Viewed 1149 times
20 Scalloping Back Braces.jpg (292.97 KiB) Viewed 1149 times
21 Branded.jpg (244.8 KiB) Viewed 1149 times
22 Sloping the Rim.jpg (277.17 KiB) Viewed 1149 times
23 Installing the Side Reinforcements.jpg (332.35 KiB) Viewed 1149 times
