Needed something to play with a vintage vibe and sound
Post by Ray Ussery » Tue Jan 24, 2012 10:37 am
By now most of you know I can't work in my shop now, and I wanted something I could pick that was light and easy and still had a great sound.
Thought you might enjoy looking at the 1960 Regal It certainly had the sound of a guitar that's 52 years old. and the size is perfect for having to be in bed all the time.
I'm am blown away at the sound and volume of a guitar that is so thin, and the bracing is really large? maybe there's a lesson here.
I get well enough to get back to it, I may try to emulate this sound and look. Anyway, here She is in all her glory!
Been searching for this or something like it to replace my little '63 M-20 Guild that was ruined in the flood 3 years ago...one day I may rebuild it too..anyway mine is exactly like this one, in the vid a '60 model 00-12 Regal...mine has a black pick guard where this one has tort.
http://www.youtube.com/watch?v=0SP0biiy2zI
Here's the specks:
This is a VERY cool little guitar...00 sized with 12 frets to the body, mahogany back and sides with a solid spruce top and X pattern bracing. The body is quite shallow measuring only 3 1/2" at the tail block and 2 13/16" at the neck joint. The scale length is 24 3/4" with a 1 11/16" nut width and string spacing of 2 3/16". I can't say with any certainty, but this guitar was probably 1960, Japanese made but was built with good materials and workmanship.. The guitar is bound top and back with decorative line purfling around the top and the fretboard is bound as well. The fretboard is rosewood, the bridge looks like rosewood dyed black. The neck has a working adjustable truss rod and the neck is straight and solid, the neck joint good and the neck angle perfect. The top shows no belly or rotation at the bridge at all. The frets are in great shape with no wear. The original finish shows some crazing here and there and a chip on the back that is through to the wood and a chip at the corner of the headstock but overall quite clean. The tuners are replaced with a set of 60s Waverlys that have been re-plated but everything else looks original, no cracks or repairs anywhere. The short scale and robust gauging of the top bracing will allow me to set this little guitar up with mediums for maximum sound production, and it is quite loud and projects quite well for such a small guitar. The tone of the guitar is very good, particularly in the mid range and trebles (thanks to the small and shallow body) but with plenty of bass presence to balance the voice well. Surprisingly good. The action is set at 6/64" at the low E 12Th fret and 5/64" at the high E, the guitar plays great for finger style with no buzz anywhere and good intonation. Also has the origional hard shell case in perfect condition.
I am HAPPY!
Re: Needed something to play with a vintage vibe and sound
Post by Dave Bagwill » Tue Jan 24, 2012 11:22 am
I like it! Thanks.
Post by John Parchem » Wed Jan 25, 2012 12:19 am
After 3 0s I have been thinking of making a 00. The pictures and the video has me even more inspired. I play a classical guitar and the 00 is not that far off.
I think what keeps these small guitars sounding good is that they are 12 fret to the body, giving them a nice bridge placement.
Post by Ray Ussery » Wed Jan 25, 2012 9:58 am
Thanks Guy's!
John,
I'm sure you are correct. I think under most circumstances the body should be deeper also and a lighter bracing arrangement.
But yes, I LOVE a smaller body. It's like an old pair of gloves, it just feels comfortable and good and still has what it takes to do the job.
Of course the 50 year old wood doesn't hurt either. On close inspection, it appears to have been put together with HHG or FISH glue or a combination of both, that may or may not have a bearing in Her sound...but not may 50 year old guitars with a neck as straight as this one, and I can't help believe that the frets are of a much higher quality than those that are available today for the most part.
The nut and bridge are either high quality bone or? don't know...certainly I don't think it's plastic, I'll have to experiment more whn I change the strings.
The fretboard shows reasonable wear but the frets do not and I swear they are origional.
When I can, I'll through a tri fold mirror inside and try to get some REALLY close up pic of the construction and try to get a light reflection from the outside showing the "Bones" and some extremely close pics of the frets and board and other components for anyone who may be interested.
Thanks again..Cheers! Ray
