Need a woodworking tip please
Post by Dave Bagwill » Thu Sep 04, 2014 4:23 pm
See pic. I have to refine the angle to 45* but the board is in place and cannot be moved. Any ideas?? Angle goes the entire 48"
Thanks
Re: Need a woodworking tip please
Post by Tim Benware » Thu Sep 04, 2014 4:27 pm
Can you post pic of the object?
Post by Dave Bagwill » Thu Sep 04, 2014 4:30 pm
I could but you've seen it - I'm refining the copy carver.
Post by dave d » Thu Sep 04, 2014 4:56 pm
How about cutting another 2x4 at the correct angle that you want to end up with, then clamp it to the existing 2x4 and using it as a guide as you take a block plane to the first one?
Post by Dave Bagwill » Thu Sep 04, 2014 5:10 pm
I like it! Thanks Dave.
Any other ideas from you forumites?
Post by ken cierp » Thu Sep 04, 2014 5:54 pm
I was thinking along the same lines as DD but I'd add a spacer to raise the plane and then use a bottom cutting router bit. The block plane would certainly do the job.
Post by Dave Bagwill » Thu Sep 04, 2014 7:35 pm
Well, this worked out just fine; as I was rooting around for another 2x4 I spied a 4' length of angled aluminum. So I used my cool tool to scratch a line down the center of the offending 2x4, marked it with a pen. I held a strip of sandpaper inside the aluminum and just made sure the angle bend stayed on the line. Went very quick, the movement of the rollers is much smoother now.
Thanks.
