new J185
tim crain 54
new J185
Post by tim crain 54 » Sat Jul 26, 2014 7:11 pm
I am working on my second J185 and have the sides bent and assembled with the end blocks and the kerfing. I have a couple of places where the sides have "rippled" and was wondering if adding additional side braces had any detriment to the sound. Different builders seem to use varying numbers of braces and I am hoping that I can flatten the sides out by the use of well placed braces. Any thoughts?? Thanks, Tim
Re: new J185
Post by ken cierp » Sun Jul 27, 2014 10:04 am
There is a school of thought that a more robust rim is a good idea -- I doubt you'd hear any difference adding more side reinforcements. On the other hand I am not to sure that will control the ripples very well. Likely they will have to be sanded/scraped out. I've had fair success eliminating ripples that I've notice before assembly, by re-bending after a good soaking with "Super Soft" veneer flattening solution.
tim crain 54
Re: new J185
Post by tim crain 54 » Sun Jul 27, 2014 5:11 pm
Hey Ken, I do have enough thickness to get most of that out by sanding/scraping but I would like to get it as flat as possible before I sand. What is Super Soft veneer flattening solution? Thanks
Re: new J185
Post by ken cierp » Sun Jul 27, 2014 5:42 pm
Super Soft 2 is a another brand name of this stuff -- I've had marginal results preventing/eliminating bend ripples with its use
tim crain 54
Re: new J185
Post by tim crain 54 » Mon Jul 28, 2014 10:11 pm
Thanks for the tip Ken
tim crain 54
Re: new J185
Post by tim crain 54 » Mon Jul 28, 2014 10:16 pm
Oh yeah, where do you get it? Thanks, Tim
Re: new J185
Post by ken cierp » Tue Jul 29, 2014 6:36 am
Google it
