I thought to use this post to start and to maintain my build thread for a Gore medium body steel string to his plan foro the Build book. I will try to follow the procedure as best I can from the book, although I can not promise I will do things in the same order, but I will at least follow the dependency graph laying out the steps.
This week I will be building the required jigs and body molds and what not but decided to start selecting and preparing the plates.
I have decided to use a Tasmanian Blackwoold set I got from Australian Tonewoods and a Lutz top I got from High Mountain Tonewood.
I followed section 6.2 Tap testing the panels for the top. This is done to get consistent stiffness form plate to plate. The vibration frequency of a plate is proportional to the Young's modulus (a measurement of stiffness). Also required are the length width and thickness of the plate.
I think I am getting good spectrum plots. The unglued plate is sanded smooth, and it needs to be rectangular. The are three different tap measurements that need to be. The long direction vibration and the cross grain vibration and a corner to corner or twisting vibration. Holding and tapping the plates in the correct location emphasizes the specific mode that is being measure.
I ended up with the following results for the top
Long Grain fl
Cross Grain fc
Twisting vibration flc
Here is just the calculation for the back plate
I think it will be awhile before I do the interesting work as I am working on jigs and forms. The 3 meter radius dish is throwing me for a loop, but I will find someone to make. I will probably have them make a 10 foot dish so that it is understandable. I have a 32 foot dish, so if no one complains I will pretend that it is a 10 meter dish. I mostly completed my body mold, still need to add the hardware.
