Ken, would you post your pics showing the dimensions for profiling the sides before bending? I've used the Om dimensions but can't find them at the moment.
Also wondering, you don't have the rise and length to the waist point for a parlor do you? I could extrapolate it from the printed plan but if it's somewhere out there already I'd appreciate it.
edit: found the one for 'D's...:
profiling the rim before bending
Re: profiling the rim before bending
Hi Darren,
The smallest I've have at the moment is the "00" in the 12th and 14th fret versions -- will those specs help?
It might help - this will be 12 fretter if it makes a difference.
Thanks Ken
Thanks Ken
~ darren
The "00" attached at the 12th fret
length 28"
neck block height 3 1/4"
tail block height 4 1/8"
inner most waist curve height 3 13/16"
Hope this is a help
length 28"
Hope this is a help
from above
"inner most waist curve height 3 13/16" - "
Or am I not understanding the question?
Ken - I meant that unlike the 'd' or 'om/ooo' profiles, the deepest part of this OO body is at the tail, not the waist. That wasn't a question so much as an observation. Sorry for being vague.
~ darren
