Sufficient glue surface?
Post by Dave Bagwill » Wed Feb 19, 2014 3:50 pm
I'm messing around with a bridge shape for the parlor guitar, trying to mimic one I've seen on old, really old, Martins.
So I had this beat-up belly bridge, and worked it a bit, and - aesthetics aside, obviously, as it's very rough yet - is there enough glue surface left after I have cut down the old belly bridge?
Bob Matthews
Re: Sufficient glue surface?
Post by Bob Matthews » Wed Feb 19, 2014 4:06 pm
Yes, imo there is enough glue area on that bridge for a parlour guitar - you don't want to be using a big fat belly bridge on a guitar with only so much soundboard area, or it will sound too bright and thin - but do bear in mind that the really early Martins were built for gut strings that had much lower tension.
Bob
Post by Dave Bagwill » Wed Feb 19, 2014 4:10 pm
The parlor bridge could also be somewhat shorter, I think - 6" might be overkill for that small top area - I may shorten it to 5". Thoughts?
Post by John Parchem » Wed Feb 19, 2014 5:09 pm
Two thoughts,
The bridge in the picture looks about the same size as a pyramid bridge which are on the Martin 0 size guitars so I think no problem for size.
I am not sure how you are bracing you parlor, If it is an X then I would make sure the bridge wings still tie into the x braces.
Post by ken cierp » Wed Feb 19, 2014 5:14 pm
The Martin pyramid bridges I have encountered are 1x6 -- that's the size of the one's we maker here at KMG.
