Any of you using a shooting board and plane for tapering your fingerboard?
My band saw, leaves a lot to be desired, and I'm really enjoying working with hand planes - seems like a clean way to taper the fingerboard. Just need to shim the fingerboard to the correct angle for the taper.
Any tips for the set up?
Shooting board for tapering fingerboard?
Re: Shooting board for tapering fingerboard?
That's what I do -- draw the guide lines on the flat side, clamp it to a straight hardwood 1x3, clamp it in vise than shave away.
With the above set-up the straight edge keeps the plane perpendicular, shave down until you touch it. Goes very fast.
I trim most of the material away on the band saw, then hand plane on the shooting board.
Works good for me.
Works good for me.
