I know the modern approach in some factories is to laser engrave their mark on center joint reinforcement strips.
I do a bit of letterpress printing and tried using a photopolymer plate and mini arbor press to stamp the strip, without much luck. I'm guessing I need to use finer detail to cut into the wood.
Are any of you marking your builds with a stamp or punch?
What is the preferred method?
Stamping center joint reinforcement strips
Re: Stamping center joint reinforcement strips
Check out the last photo
viewtopic.php?f=24&t=1111
I use an old fashioned woodburner with pointed tip and freehand my last name and the date on the joint reinforcement. Never have understood why it is OK to paste in a large paper label on top of all that fancy tonewood, though it probably is.
