I finally came up with my bridge design and finished the bridge last weekend. I am at the point of locating the bridge so I can make the mask and proceed with the finish. So once more I am going to ask for input on compensation just so I have as much information as possible before making the decision on the saddle location/bridge placement. The scale length is 24.75" (628.65mm) and the plans call for approx. .130" (3.30mm) compensation at the high E string. This works out to approx. .1730" (4.4mm) at the center of the slot (in between the 3rd and 4th string) with my 3% slot angle. This is a bit more than the .15" (3.81mm) recomended by Cupiano though his calculations are for scales of 25" to 25.75" and from what I have read the shorter the scale the greater the amount of compensation needed. Looking through my books (Kinkead, Young, Sloan) the measurements on my plans seem to be in the ball park though all of the information in the books is based on longer scale lengths, approx. 25.4. I was wondering if any of you had built a J185 using the Scott Antes plans or any other 24.75 scale guitar and what compensation you used. I attached a few pic of the bridge, the holes in the "wings are for locating pins and will be covered by a yet to be determined inlay. Thanks again in advance for any input, I know this is a very critical step and I am pretty nervous about it.
PS: Sorry about getting the pic sequence reversed, one day I WILL figure it out!!
bridge placement
bridge placement
- finished bridge with another blank for reference
- IMG_1662.JPG (94.2 KiB) Viewed 1292 times
- rough shape with the saddle fitted
- IMG_1648.JPG (151.51 KiB) Viewed 1292 times
- cutting the slot
- IMG_1646.JPG (115.88 KiB) Viewed 1292 times
- template, laying out on the blank
- IMG_1645.JPG (150.09 KiB) Viewed 1292 times
Re: bridge palcement
Because of all the chatter and erroneous information regarding intonation and compensation other than selling our tools for bridge/saddle placement that put it in the right place, I don't get involved in explaining and detailing dimensions or the process. But I will say that these are incorrect assertions
Thanks Ken.
It is also useful to use a wider saddle, it gives greater flexibility for intonation. Mike Doolin, for instance, uses a 1/4" thick saddle. I've done that as well and it works great. But at least 1/8" if you can. 3/32" has been used on about a zillion guitars and can be made to work, but a little more thickness makes things much easier.
Well those appear to be the pictures from Kinkeade's book doesn't his numbers work? I just finished his book not two hours ago.
Lonnie I'm not sure if Kinkead's measurements work or not that is why I was asking for input. They seem to be in the ball park to what I have in mind but being my first acoustic build and not having the luxury of and adjustable bridge I was hoping for some input from of the more seasoned builders. Bridge placement being one of the most critical steps in construction I wanted as much info as possible before pulling the trigger. Thanks for your interest and I will let you know how it goes. Thanks again, Tim
Dave I have a 1/8th - 3mm saddle so not a lot of room for error. I need to be close right from the start then I can make minor adjustments from there. Next time may be a wider bridge is the way to go. Thanks much for the input, I need to look at all the options before I position this thing. Thanks again, Tim
