Here's a knock off of the Sloane router attachment -- easy to make, easy to adjust
Rosette channel Dremel/router attachment
Re: Rosette channel Dremel/router attachment
I made one; it's easy to make and it works very well. And saves a lot of $ compared to the over-priced thing sold commercially.
Yeah... good device. I made something similar out of 1/4" and 1/8" plexiglass.
Ts Paxton
Ts Paxton Guitars
Ts Paxton Guitars
Ken,
I assume that if I use your binding router attachment on my Bosch laminate trimmer, I should be able to make use of this attachment. And if so, is the vertical adjustment done with the trimmer or another piece attached to the jig?
Woody OKeefe
Prescott,Arizona
Prescott,Arizona
Yes the depth is a function of the trimmer base -- I have only used this in our shop with a Dremel with the router base. I do know that some guys made one for their Colts and Harbor Freights --- hopefully they will chime in.
WOWOW...."Thing-a-ma-jigs" and "Doo-Dads" and constructions and destructions and baseball and "Stuff" all over the place...I have one of those "Thing-a-ma-jigs" I bought from Ken...and now maybe a Doo-Dad" if I'm smart enough to follow the pics...how much better does it get?
Thanks guy's!
For the laughs AND the knowledge!
Ray :>)
Thanks guy's!
Ray :>)
Ken, I gave my Air Turbine another adjustable base. I used the print you posted, so I wanted to thank you and send a couple pictures along. I had a few orphan pieces of solid surface countertop hanging around and it is pretty easy to work with. The pin used for the pivot is an old screwdriver shank. This one is extremely hard...couldn't cut it with a hacksaw. So again thanks for the post.
- DSC21556_1.JPG (722.86 KiB) Viewed 2487 times
"Good enough, never is"
Kim Hillard
Burdickville, Michigan
Kim Hillard
