Baked Tops
mike-p
Baked Tops
Post by mike-p » Tue Oct 22, 2013 10:22 am
Hi Y'all,
Just been on a short trip to the states and obviously went to some guitar shops. We don't get a lot of the higher end US small shop guitars in the UK so I was keen to try some. Tried a Bourgeous Aged tone mahogany dread and it was pretty outstanding, huge tone, not the same as an old guitar but remeniscent of one and certainly more beautiful than the even louder Collings dread i tried.
Read a few posts around about baking spruce tops, anyone tried this?
Also, does anyone notice any difference with tops that have been cut and stored for longer?
Thanks for your thoughts.
mike-p
Re: Baked Tops
Post by mike-p » Tue Oct 22, 2013 10:24 am
Re: Baked Tops
Post by ken cierp » Tue Oct 22, 2013 11:35 am
All Taylor sound boards are baked -- at about 225 degrees.
So if you like Taylors you might want to go through the trouble?
Re: Baked Tops
Post by TonyinNYC » Wed Oct 23, 2013 9:18 am
One of the theories behind baking the tops is that it is supposed to "set the resin" in the course of an hour or two as opposed to the resin setting on its own over the course of several years or decades of seasoning. Seasoning wood, is just what it sounds like. Letting the wood sit out, exposed to the seasons. My wood is all stored in an uncontrolled environment. My garage. It is not heated, cooled or RH controlled. Most of my wood is now a few years old. It gets really hot in the summer and it freezes in the winter. I bring it to a controlled environment for a few weeks before I use it.
The resin in the wood dries and crystallizes out more slowly than the trapped water in the wood. Seasoning the wood allows it to shrink and expand and change RH for a long period of time, slowly crystallizing the resin. Baking does a similar thing in a short period of time. This crystallization of the resin can also happen over time once the guitar has been built. Which can account for a change in the sound of an older guitar versus a new one.
On another forum, a guy baked his top three times. I am giving you this info from memory, so it is not 100% accurate but here is what he did:
Weigh the plated before baking. Bake for 60-90 minutes at 200*F. Weigh the plates again. Wait 24 hours and then re-weigh the plates. Bake plates again for 60-90 minutes, weigh again, repeat.
He then weighed the plates 24, 48, and 72 hours after baking the third time to see if there was any weight change. The plates were kept in a stable environment after each bake cycle. 45-50%RH and 72*F. He found that after the first bake cycle, the plates lost the most weight, but regained most of it before the next cycle. After the third cycle, the plates had lost some weight and only regained a small amount in the days after. After the three cycles, the plates did regain some weight, but did not go back to their original weight. He also claimed they felt and sounded more lively when tapped after the baking cycles, however, that was purely subjective as he had no way to measure the actual response.
Having said all of that, I can tell you that I have not heard one person who bakes their tops say they regret it or that it was not worth the time. Some have said they are not sure if baking did anything, but they still said they would bake again. Me? I have not baked a top yet. To do so would require my wife leaving the house for several hours and that rarely coincides with my brain remembering to grab a sound board to bake!
Re: Baked Tops
Post by ken cierp » Wed Oct 23, 2013 9:31 am
Drying Spruce: Nature or Nuture?
Bob Taylor
June 16, 2010
Guitar making is a mystery to many of us and embellished with lore. I once spoke to wood technologist Bruce Hoadley, author of Understanding Wood, and mentioned that we guitar builders think that as wood gets older the resins break down, thus causing a guitar to sound better and to maintain stability, to which he said, “That’s great. What resins are you talking about?” To which I answered, “Well, I don’t know.” I’m a dork.
He went on to say that he thinks it’s like chicken noodle soup, which people say makes them feel better when they’re sick, and it probably does, but let’s just go with the idea that it does, and not try to explain it because we don’t know what we’re talking about. So, he believes that older guitars sound better, but he cautioned me to be careful about saying why.
That was about the time I wanted to find out about spruce shrinking and if there was something I could do about it. So, I’m going to get all technical on you and tell you about some experiments I conducted about 15 years ago and how those led to my current techniques for drying wood.
Testing the Field
The scientific method is to have a hypothesis, to test it with an experiment, and then to accept the results of that experiment. That’s hard to do because often the results aren’t what we want to see and so we often are tempted to ignore them. But this was a dispassionate idea, which was to simply find out how much spruce shrinks after being dried, either naturally, or through a forced process (thus the title of this article).
Step one was to take a group of tops, air dried and kiln dried, equalize them to 47 percent relative humidity (RH), then cut and mill them to the exact thickness of my dreadnought model. They were then measured for width to the thousandth of an inch and weighed on a gram scale. Next step was to equalize them to 30 percent RH. “Equalizing” expresses the state where wood has absorbed or given off the necessary moisture to be even with the surrounding RH.
Next was to weigh and measure each piece. The results were that they lost between a 1/16" and 1/8" in width and lost significant weight due to water being removed from the lower humidity. An eighth of an inch is enough to crack some guitars, so what to do?
During this time, I also asked for the help of every guitar factory you can imagine. I asked them to send a top to me that was ready for bracing, seal it in layers of plastic wrap, and then overnight it to me. I measured and weighed each piece as soon as I opened the pack, and proceeded to equalize it to my factory, then measured again. By doing this I was able to compare the humidity levels of all the shops and factories around the U.S. at the time. Then I proceeded to find out if any of their drying methods worked better than those I had been using. They didn’t, and their spruce exhibited the same shrinkage factors. This sampling included 20-year-old tops and tops which were salt-water cured, a method we guitar makers have heard about that some people say Stradivarius employed. None of them performed better than the others.
Lessening the Shrinkage
To keep this article short enough to read, I’ll fast forward to the final drying method that I came upon. That is to heat the spruce to 200 degrees for 30 minutes, or in other words, bake it. I call it oven-roasted. I do know that the pitch in spruce will “set” at 180 degrees, but more than that, nearly every bit of water is driven out of the wood through this process. The next step is to re- equalize the spruce to 47 percent RH, which hydrates it back to “normal,” but at this point it is permanently smaller than it was before it was heated. Upon exposing these pieces of spruce to 30 percent RH, they now only shrank between 1/32" and 1/16"! That is half as much as before and enough to eliminate most of the cracking that might occur on a guitar that is dried due to exposure to low humidity.
I shared with the results with all the builders who contributed tops to the experiment. I immediately employed this method of drying and have done it ever since.
Did it help the sound? I can’t tell, but it didn’t hurt it. It certainly helped the shrinkage factor. Does it still shrink? Yes, but less than before. Point is, there was enough scientific method employed to come up with a drying method that proves to be better than air drying when it comes to the stability of the wood.
When it comes to the mechanical performance of a guitar, I think that an approach like this works very well. We use a similar method for designing the sound (making samples with small changes), but the results are much more subjective because it’s a value judgment in the end. I suppose we could use some kind of meter to tell us what the guitar sounds like, but that just makes me cringe, so I’m not signing up for that. I suppose that’s why guitar making is considered a blend of art and science.
mike-p
Re: Baked Tops
Post by mike-p » Wed Oct 23, 2013 10:00 am
great info guys, thanks.
Re: Baked Tops
Post by Kevin in California » Wed Oct 23, 2013 12:38 pm
I like that from Bob Taylor. I may give it a try, but I won't go off half baked and try it right away.
