Tim Crain's J185
Tim Crain's J185
cutting the dovetail for my J185, now all I have to do is get it to fit!!
- IMG_1254.JPG (153.15 KiB) Viewed 1467 times
- IMG_1255.JPG (154.19 KiB) Viewed 1467 times
- IMG_1247.JPG (145.77 KiB) Viewed 1467 times
Re: J185 neck and dovetail
I've never done a dovetail, but just looking at it, why not just hit it hard with a big mallet??
Just kidding of course - I'm sure you'll do fine.
I think I will use my 3 ton arbor press, more control.
I would not do any more fitting until you shape the heel and carve in the cheek relief. Is there a set angle machined on the neck? Nice work!
no, all by hand. I did cut the angle complimentary to the angle of the top, about 89 degrees +or-.
j185
Wow!! I think this may actually work!!
- IMG_1260.JPG (162.13 KiB) Viewed 1454 times
- IMG_1261.JPG (134.07 KiB) Viewed 1454 times
- IMG_1263.JPG (147.26 KiB) Viewed 1454 times
Re: Tim's J185
got the neck fitted, a couple of small gaps but not too bad. The finger board is just held on with the alignment pins and the neck is just held by the dovetail. Glued on the heel cap and called it a day. Do you guys (and gals) fret your fingerboard prior to gluing it to the neck?? Seems like it would make things easier but can you keep it flat enough?? I would appreciate any opinions. Thanks in advance, Tim
- IMG_1269.jpg (138.78 KiB) Viewed 1426 times
- IMG_1272.JPG (156.42 KiB) Viewed 1426 times
- IMG_1271.JPG (133.61 KiB) Viewed 1426 times
- IMG_1267.JPG (131.43 KiB) Viewed 1426 times
- IMG_1265.JPG (123.72 KiB) Viewed 1426 times
- IMG_1273.JPG (127.15 KiB) Viewed 1426 times
- IMG_1275.jpg (108.8 KiB) Viewed 1426 times
