Fretboard taper
Fretboard taper
Post by Dave Bagwill » Thu Jul 18, 2013 10:36 pm
See pic. Is that a taper on the fb, and is it something you do?
Bob Matthews
Re: Fretboard taper
Post by Bob Matthews » Fri Jul 19, 2013 6:22 pm
Where on earth did you get that picture from? It looks like a mess to me! :D
The treble/top 'e' is set much too far away from the fretboard edge and the bass/bottom 'E' is floating so high that I had to laugh.
As for the taper - I presume you mean across the fretboard - with the bass side being much thicker than the treble? The only thing I can think of here is that the maker wanted the guitar to sound more bassy by using a greater string height at the bridge over the soundboard at the low E and much less height at the treble e.
Personally, I like to try to create a balance across the strings and would not be happy if the guitar was bass or treble heavy and in an ideal world I would like the volume of the treble strings to match the volume of the bass strings. There are many other ways to create a guitar that accentuates either the bass or treble that would suit the player's requirements.
So to answer your question Dave, no, it's not something I do.
Bob
Re: Fretboard taper
Post by Tim Benware » Fri Jul 19, 2013 7:02 pm
Not me and if I was to use something like that wouldn't you want it to go the other way so the treble would be close and the bass side higher without having to adjust the saddle?
Re: Fretboard taper
Post by John Parchem » Fri Jul 19, 2013 7:18 pm
On my classical guitars I taper the bass .5 to 1 mm thinner than the treble. To see the opposite is weird, but I would need to see the whole guitar.
Re: Fretboard taper
Post by ken cierp » Fri Jul 19, 2013 7:40 pm
Ditto -- John seems backwards?
Re: Fretboard taper
Post by Dave Bagwill » Fri Jul 19, 2013 9:27 pm
I think the angle of the pic through you - and me- off. This guy knows what he's doing. I'm going to contact him about it.
Re: Fretboard taper
Post by Dave Bagwill » Sat Jul 20, 2013 9:58 am
Here is the luthier's reply:
"I think this is just an artifact of the camera angle. Both sides of the
fretboard are the same thickness at the end."
So, sorry to go on the wild-goose chase.
