Gluing my bindings
Paul C
Gluing my bindings
Post by Paul C » Sun Jul 14, 2013 11:27 pm
My bent purflings and bindings ready to go. I am thinking regular titebond on this glue up. What do you all think.
Re: Gluing my bindings
Post by ken cierp » Sun Jul 14, 2013 11:37 pm
Titebond, Elmers, Duco all work well for wood purfs and bindings. The CA method is certainly the quickest but requires sealing the channels with lacquer.
Post by TonyinNYC » Mon Jul 15, 2013 11:11 am
The plus to Titebond is that it will swell the wood a tiny bit and fill in some small, small, gaps.
CA lets you snug the binding up tight, then glue. Having used CA on several guitars, I did the two most recent guitars with Titebond. I may go back to it exclusively. I like the results and it is not nearly as hard as I remember it being. The key, is having bindings that fit the box well. If you have a KMG kit, you should be fine using Titebond. I put the glue on a plate, and use a brush to apply it to every side of the binding and purfling that touches the box or each other. Get your tape strips ready before you start gluing. I put about 50 strips on the edge of the table and then start gluing.
Paul C
Post by Paul C » Mon Jul 15, 2013 4:45 pm
Titebond it is then. Thanks for the tips. Let you know how it goes.
