Has anyone used or owned this drum sander? I've heard
that the paper is hard to change on them but that's it.
Ryobi WDS 1600 Drum Sander.....Any Good?
Re: Ryobi WDS 1600 Drum Sander.....Any Good?
I have one, got it used in great shape for $150 locally of Craigs list about 2 years ago.
I have no problems changing the paper. I found a user manual online and it shows how to do it.
This is the only drum sander I've owned so I can't compare it to any others, however it works fine for my purposes. The outboard side does not have a support and there can be a little bit of give (pushes up) as the wood passes under. I've measured this to be about .005" difference, so I try and stay in the middle area as much as possible, but for most of what I'm doing I can live with the .005".
Do you have a line on one? What is it going for?
Hi Kevin,Kevininca wrote:I have one, got it used in great shape for $150 locally of Craigs list about 2 years ago.
Thank you for the info but the guy sold it. He was going
to sell it to me for $250 but someone offered more I guess.
So close....
Mark and others --FYI even changing abrasive on our $6000 37" Dual SuperMax Sander is a PITA. Make sure to wear gloves with the Blue Zirconia (which is all we ever use) As a matter of fact this last change over I cut the strip a tiny bit short (duh) - a trick I saw at the Grizzly Warehouse in PA, is to use filiment strapping tape to capture the ends, to my surprise this works really well
