Clean bridge plate holes
Post by Tim Benware » Sun Jun 09, 2013 10:50 pm
One of my pet peeves is bridge pins holes with splinters across them. Here's how I get clean holes.
I take a piece of scrap about 1&quot; x 3&quot;, in this case a piece of mahogany and use double sided tape to stick it to a cam clamp.
I take a piece of scrap about 1" x 3", in this case a piece of mahogany and use double sided tape to stick it to a cam clamp.
IMG_4305 (800x600) (800x600).jpg (446.25 KiB) Viewed 825 times
Then I clamp it to the bridge plate.
IMG_4306 (800x600) (800x600).jpg (366.86 KiB) Viewed 825 times
Drill the outside hole (here are two sets because I am finishing 2 guitars).
IMG_4308 (800x600) (800x600).jpg (363.5 KiB) Viewed 825 times
Next drill all the way through the block.
IMG_4309 (800x600) (800x600).jpg (378.49 KiB) Viewed 825 times
A couple screws and wing nuts to re-attach it to the plate.
IMG_4310 (800x600) (800x600).jpg (397.68 KiB) Viewed 825 times
Drill the remaining 4 holes...
IMG_4312 (800x600) (800x600).jpg (351.98 KiB) Viewed 825 times
... and Voila! Clean holes.
IMG_4315 (800x306).jpg (183.66 KiB) Viewed 825 times
Re: Clean bridge plate holes
Post by Dave Bagwill » Sun Jun 09, 2013 11:25 pm
Nice, Tim!
Post by TonyinNYC » Mon Jun 10, 2013 9:11 am
That's a great tip. I have always struggled to get clean holes (don't even think about it Bagwill! Just let it go). Thanks for posting!
Post by ken cierp » Mon Jun 10, 2013 10:06 am
Nice tool.
I normally use the double stick tape trick and a sacrificial caul (scrap wood). I move the cam clamp to do the RH and LH -- three holes at a time. The scrap is cut to match the "X" angles so it pretty easy to locate blind. Yes I throw it away after one use.
Kyle Barbour
Post by Kyle Barbour » Mon Jun 10, 2013 10:28 am
That's a great idea. Thanks!
Kyle
Ron Belanger
Post by Ron Belanger » Mon Jun 10, 2013 1:09 pm
kencierp wrote:Nice tool.
me too.
Lee in UK
Post by Lee in UK » Mon Jun 10, 2013 5:23 pm
You just need a hard wood plate to go over the bridge plate and under the bolt heads to save getting those indentations in the plate from the bolt heads!
