Do I need a 28' radius dish or is there another way?
MarkAndrew1
Post by MarkAndrew1 » Thu Jun 06, 2013 1:50 pm
I'm getting ready to brace the top on my guitar. I plan
on using a 28' LMI brace radii (?) sander to radius the X braces.
Now, problem is, I don't have a 28' dish to sit the top in
when I glue the bracing on so what do I do? Suck it up and
buy another dish (I already have a 15' dish) or is there
another method I could use?
Re: Do I need a 28' radius dish or is there another way?
Post by Dave Bagwill » Thu Jun 06, 2013 1:56 pm
A number of us use this method, and it works very well:
http://www.kennethmichaelguitars.com/contourtool.html
If I understood your question....
MarkAndrew1
Post by MarkAndrew1 » Thu Jun 06, 2013 2:12 pm
deadedith wrote:A number of us use this method, and it works very well:
Okay, that...........is brilliant!!!!!!!!!!!
Thanks!!!!
Post by dave d » Thu Jun 06, 2013 3:28 pm
Thanks!!!!
It's the only method I've used to date, and works great.
Post by Tim Benware » Thu Jun 06, 2013 11:43 pm
I glue mine to a flat surface and let the radius on the x brace spring it back, same method Martin uses.
Post by ken cierp » Fri Jun 07, 2013 7:10 am
Tim is correct Martin's fixture is almost flat but so are the braces, a mere 52' radius and some (16's and below) are flat. They do not however, radius the braces to 28' and flatten them out --- that is a simply an Internet myth. Sorry Tim, I totally disagree with this practice --and in fact the myth got start because of bad information which is the incorrect convensional wisdom that Martin uses a 28' radius on any part of the guitar (rim or bracing) they never have and are very proud that they build flat top guitars.
MarkAndrew1
Post by MarkAndrew1 » Fri Jun 07, 2013 10:08 am
So, Ken.....Just to be clear, Martin puts a 52' radius on the
X braces? The internet is full of misinformation because I've
seen multiple places where people say it's 28'; But this is my
fact vetting forum!!!!!! hahah I'm trying to build my dread
as close to Martin specs as I can.....
Thank you!
