How to remove this?
How to remove this?
Post by Dave Bagwill » Tue Apr 30, 2013 5:31 pm
Pull off the collet? I have removed the screw, inside the jaws, that hold the collet on the quill, but I cannot get it to budge. Worried about bending the quill, of course.
Ideas?
Re: How to remove this?
Post by ken cierp » Tue Apr 30, 2013 5:36 pm
Maybe its threaded? That's the way hand drills work.
Post by Dave Bagwill » Tue Apr 30, 2013 5:38 pm
Not this one unfortunately.
Customer service, I guess...
Thanks
Post by ken cierp » Tue Apr 30, 2013 5:56 pm
If its tapered you need a wedge tool --- if its threaded (I guess it not) This shows both
http://www.ereplacementparts.com/articl ... html#taper
I don't recall ever seeing a taper press fit check with a set screw.
Post by Dave Bagwill » Tue Apr 30, 2013 6:47 pm
The screw is inside the jaws, straight up into the chuck.
The Ehow guy showed a piece of hardwood and a hammer. I tried it and it knocked right off.
Thanks.
I used to call that technique 'percussive maintenance' when certain computers were acting up - a good whack worked better than the IT guys...
Post by Tim Benware » Tue Apr 30, 2013 7:23 pm
So it turns out it had a screw and was press fit?
Post by Dave Bagwill » Tue Apr 30, 2013 7:38 pm
Press fit, then screwed.
