Using my MM to...
Using my MM to...
...draw a side profile of the cutaway side for my next guitar.
- IMG_4090 (800x600).jpg (379 KiB) Viewed 1223 times
- IMG_4091 (800x600).jpg (370.7 KiB) Viewed 1223 times
Re: Using my MM to...
I was showing a student how to do it, got almost all the way around to the end block before it dawned on me I was not using the radiused side of the bar. Close call. But really a clever way to get the perfect profile!
Here's the explanation of the entire process:
http://www.kennethmichaelguitars.com/si ... lates.html
And here it is with the back radiused. I had a couple lumps to smooth out on the cutaway side and I got the blocks a little more proud of the sides than I should have (I wanted extra in case I needed it, turn out I really didn't) but all-in-all I think it looks great.
So Ken, when I flip it over in the mold is there any tricks to not having to change the cutaway from one side to the other? I know I'll have to this time but should I make a cutaway insert and just set the profile to a non-cutaway?
- 20 Back Radiused.jpg (419.76 KiB) Viewed 1165 times
Get the kerfing installed to stiffen up rim -- then you can flip it, you then need to capture the neck block so it in the proper alignment with the TB, as seen here:
viewtopic.php?f=15&t=94
Thanks, I like that process flow.
