I started a teaser thread on this in the Gallery. Be busy building and now it's time to post some pics.
et.com/albums/ee370/Ben-Had/12FlatBraceGlueup_zps1e730525.jpg[/img]
Pre-war Martin Style
Re: Pre-war Martin Style
Kerfing and stuff.
- 18 Headsock glue Up.jpg (411.98 KiB) Viewed 937 times
- 19 Headstock 2 (800x600).jpg (544.42 KiB) Viewed 937 times
- 15 Kerfing glue Up.jpg (451.63 KiB) Viewed 937 times
- 16 Kerfing In.jpg (433.38 KiB) Viewed 937 times
- 17 Fretboard.jpg (388.81 KiB) Viewed 937 times
Is that oak you are using for sides?
Honduras Rosewood.5527paul wrote:Is that oak you are using for sides?
Some fret board and neck work.
- 30 Neck 12 (800x600).jpg (462.14 KiB) Viewed 922 times
- 21 Volute Outline.jpg (436.14 KiB) Viewed 922 times
- 22 First Cut.jpg (365.66 KiB) Viewed 922 times
- 23 Volute Shaped.jpg (373.49 KiB) Viewed 922 times
- This is a T-Bar truss rod.
- 24 T Bar In.jpg (522.1 KiB) Viewed 922 times
- 26 FB Glue Up.jpg (477.25 KiB) Viewed 922 times
Scalloping and attaching the top.
- 27 Top Bracing.jpg (399.13 KiB) Viewed 922 times
- 28 Finger Planing the Finger Braces.jpg (392.06 KiB) Viewed 922 times
- 29 Top Glue Up.jpg (462.63 KiB) Viewed 922 times
- 32 Top Attached.jpg (457.78 KiB) Viewed 922 times
Box closed and time to bind.
- 38 Top Side.jpg (419.22 KiB) Viewed 922 times
- 39 Back Side.jpg (412.88 KiB) Viewed 922 times
- 41 Herringbone Ledge.jpg (390 KiB) Viewed 922 times
- 42 Taping Off Body for Binding.jpg (386.61 KiB) Viewed 922 times
- 43 Perparing Binding Tape.jpg (396.35 KiB) Viewed 922 times
- 44 All Taped Up.jpg (393.54 KiB) Viewed 922 times
