This is the instruction set from the KMG instruction manual -- the special clamp is worth the effort and helps insure all the rings are seated properly
http://www.kennethmichaelguitars.com/rosette.html
Installing rosettes with Duco Glue
Re: Installing rosettes with Duco Glue
I like the bevel method and will be using it when I install my first rosette.
David L
David L
