harp ukulele project - Gluing down the bridge...
Re: harp ukulele project - So close ...
Post by John Parchem » Fri Dec 21, 2012 4:21 pm
Thanks guys,
I am going to make a ukulele vacuum clamp for the bridge today or tomorrow so I can finish this instrument.
Post by Dave Bagwill » Fri Dec 21, 2012 4:49 pm
John I am not suggesting you do it this way - but I was reading a thread on some luthier forum who members do the following:
Prepare the bridge and the surface it is being glued to
Prepare the HHG
Apply the glue
Rub the bridge on the top, forming a rubbed joint (I think there is another name for that process)
Use finger pressure only for a minute or so
Walk away and let the HHG do its thing.
They claim no failures over a period of years.
Gonna try it? :-)
Post by John Parchem » Fri Dec 21, 2012 5:11 pm
deadedith wrote:John I am not suggesting you do it this way - but I was reading a thread on some luthier forum who members do the following:
Prepare the HHG
Apply the glue
Gonna try it? :-)
I have read that as well. I have a gluepot and hide glue ... but I have no experience with the glue. Also the joint has to be prefect. I may be wrong but I think a rubbed joint is relying on a vacuum like attraction between two perfectly matched surfaces. I will get the surface really close sanding on the ukulele itself but I am not sure I want to roll the dice again with a new way. Thinking more about this technique ... I am using index pins to get the bridge exactly where I want it, the pins seem to rule out the rub joint. Maybe I am wrong.
Post by John Parchem » Sun Dec 23, 2012 6:35 pm
I figured out how to glue on the bridge! (Hopefully). I was struggling how to glue the bridge on to the harp ukulele. My main problem was my hand is too big to get a caul in the right spot in the instrument. I was working on a vacuum clamp, but ran into two problems. The first was as this is an 8 string instrument with four of the strings off on one side, I could not make a vacuum clamp that would give me enough space around the bridge and still stay on the instrument. I could have gotten the one I made to work except for the second problem, my impatience waiting for the gasket material to come in the mail.
Anyway I finally had a flash on how to get the caul in and hold it as you can see in the pictures. I took off the blue tape before I glued down the bridge! I did run the whole procedure twice by my self before gluing for real. Also on the real run I had my son help.
Re: harp ukulele project - Gluing down the bridge...
Post by John Parchem » Sun Dec 23, 2012 6:38 pm
btw sorry about most of the photos my website went down yesterday and no one is at the hoster to fix it :(
Post by Dave Bagwill » Sun Dec 23, 2012 7:26 pm
Nice ingenuity John!
Post by Kevin in California » Mon Dec 24, 2012 12:50 pm
Very clever indeed. Isn't it amazing how our minds can figure stuff out.
Good job John.
