Construction Log for KMG J45-Style Dreadnought
Re: Construction Log for KMG J45-Style Dreadnought
Post by TonyinNYC » Thu Mar 07, 2013 12:37 pm
Great work and excellent pics! I have gotten lazy and use my phone for progress pics. I should bust out the good camera from time to time.
Post by dave d » Fri Mar 29, 2013 11:28 pm
More photos of the bracing process.
Using my small ruler to line up the location of the notch for joining the x-brace pieces.
Line marked.
Now joining the vertical lines across the top of the x-brace.
x-brace pieces glued together, but not glued to the soundboard yet.
Gluing on the bridge plate.
Placing the clamping cauls (3x5 cards) on the workboard.
Now with the bridge plate glued on and used as the anchor point, glue on the x-braces.
Top bracing glued and carved.
George
Post by George » Sat Mar 30, 2013 8:53 am
Fantastic!!! I’ve learned a lot from viewing your logs. I just ordered a J-200 kit,,,, inspired by your last build.
Thanks for posting such great pictures.
George
Post by TonyinNYC » Tue Apr 02, 2013 9:24 am
Very nice job on the lap joint. That is one joint I take extra time with to ensure it is nice and tight. I like when I need to sand the side of one brace to make them fit together.
Is this a KMG kit? The bracing has such tight grain lines. Looks like top notch stuff. One time, I placed an order with Ken for something, I forget what, but in the conversation we got to talking about bracewood and such. Ken sent me some of his reject braces to use for whatever I wanted. He rejected some because of pitch pockets that were revealed in the milling process, some had a small grain deviation because of the proximity of a knot when the tree was whole, but all in all, I have been able to salvage a lot of the brace stock by making shorter braces out of them. All of the brace stock has straight, tight grain, exactly what I would pick for my own use, and all of it was light and strong. I wonder how much material Ken rejects because it does not make the cut (see what I did there DaveB?).
I have yet to see a bad piece of wood in any of his kits that have been built here.
Post by dave d » Tue Apr 02, 2013 9:43 am
Yes indeed Tony, that's a KMG product. All of the bracewood is great. And so are the rest of the components of course!
Post by dave d » Thu Apr 11, 2013 11:02 pm
Time to update my building log. Most photos are self-explanatory, but if you see something and think "what in tarnation is he doing there?" then just shout.
a nice snug fit around the rim
And voila, the back is suddenly glued on too. And the overhangs have been trimmed off with a router and a flush cut bit.
Thanks for looking.
Doing some sanding here to get the sides flat before I begin cutting the binding/purfling channels.
Post by dave d » Fri Apr 12, 2013 8:37 pm
With a wipe of a rag dampened with mineral spirits the grain of the walnut sure looks fantastic.
Preparing to cut the binding channels.
This would work better if there was a router attached to it. :)
I tried using fiber-reinforced tape this time. It works quite well.
As I try the fit of the binding and purfling, I make a note of where I could use just a smidgen more depth, and use either a small plane or sandpaper to tweak it.
