Sanding right up to the fret
Re: Sanding right up to the fret
Post by Dave Bagwill » Thu Feb 21, 2013 11:18 pm
Maybe something like this, if we want to sand rather than scrape?
http://www.flex-i-file.com/alpha/sanding-files.php
Post by Kevin in California » Fri Feb 22, 2013 12:22 am
Ditto on the razor blade Dave. I've thought about mounting a half of a blade in a handle so my fingers aren't in the way when trying to get that blade right up against the fret, and also on braces (I started carving/sanding back braces tonight and used the razor blade, and thought again I need to mount the thing in a handle).
You do want to go with the grain, and scraping seems to be the best way. Work with the razor blade more, and figure out a handle so you can have better leverage and control.
Post by Dave Bagwill » Fri Feb 22, 2013 1:27 am
Actually I do have such a holder and have been using it for a couple of years. I use it for many things including getting scratches out that are between the frets.
I guess I'm just having trouble getting my question across: DO YOU HAVE A TOOL OR METHOD FOR SANDING SCRATCHES RIGHT UP NEXT TO THE FRET??? :-)
In other words, for this little job on my bench right now, I really really really want to SAND, not scrape. I know how to scrape with a razor blade but for this job I have not been successful with the blade.
Whew!! I feel like I've run a mile. Actually that was back in the day; now, I feel like I've sat up in my recliner. :-)
Post by Tim Benware » Fri Feb 22, 2013 1:35 am
You can take a small piece of cork (as a sanding block)and PSA sandpaper or double sided tape to stick the sandpaper to it. Don't "wrap" the paper on the block or it won't get right up to the edge. I also have a "Holy Terror" sanding block that I have cut up into small pieces for just this purpose. It is firm enough to get pressure yet flexible enough the follow the radius.
Post by Dave Bagwill » Fri Feb 22, 2013 1:43 am
Hesitate to ask: what is a 'holy terror' sanding block?? LOL
Post by ken cierp » Fri Feb 22, 2013 9:12 am
This is what I use for fine work in tight places
Post by Tim Benware » Fri Feb 22, 2013 9:46 am
kencierp wrote:This is what I use for fine work in tight places
That looks like a good tool. May had to investigate further (that means buy it!)
Here's the Holt terror (I got them on sale in a 2 pack for less than this price for one):
