Plane meets nail
Re: Plane meets nail
Here's how I did it; turned out very well. Sorry for all the pix but someone someday may find a use for them.
- The culprit. Luckily only on the second bevel, a smaller area.
- 1.jpg (275.77 KiB) Viewed 853 times
- Using a shopmade bench hook to extend the blade the correct distance for the jig.
- 2.jpg (172.33 KiB) Viewed 853 times
- Making sure the blade is square to the honing jig.
- 3.jpg (183.6 KiB) Viewed 853 times
- I have a double bevel, 25* plus 8* = 33*
- 4.jpg (200.45 KiB) Viewed 853 times
- 33* on 220 grit taped on a large flat tile.
- 5.jpg (191.17 KiB) Viewed 853 times
- Chip is gone.
- 6.jpg (161 KiB) Viewed 853 times
- A little touchup on the 400 and then the 8,000 grit stones - a minute's work or so.
- 7.jpg (198.31 KiB) Viewed 853 times
- Result - some satisfactorily lacy-thin shavings.
- 8.jpg (188.53 KiB) Viewed 853 times
P.S. - thanks for all the advice. The Forum rocks.
Congrats on a successful procedure Dave. Looks like you've got a nice secondary bevel there. Thanks, now I have 4000/8000 grit stone envy :)
Are you going to camber it at all or leave it square? (Or maybe there is one but I can't tell)
A slight camber.
And btw, that's a 40 micron/325 grit stone (diasharp) , then the 8,000 takanako stone. Brian Burns over the years has discarded the middle grits and found this system, straight from 40 micron to 8,000 grit, works just as well. Works for me, quick and easy.
