Cocobolo O’M
John J
Re: Cocobolo O’M
Post by John J » Mon Nov 18, 2019 12:28 pm
Thanks Herman. Here’s the top glued to the rims and ready for the back.
JJ
Re: Cocobolo O’M
Post by John Parchem » Fri Nov 22, 2019 2:34 pm
gorgeous work! So that pickup also has an internal microphone? Is there a way to mix between the under the saddle and the microphone?
John J
Re: Cocobolo O’M
Post by John J » Fri Nov 22, 2019 2:59 pm
Thanks John. No that is a volume wheel. I didn’t want to risk getting finish on so it’s just taped out of the way.
JJ
John J
Re: Cocobolo O’M
Post by John J » Thu Dec 05, 2019 11:24 am
Box is about done. Just some finish sanding.
Ebony binding.
Ebony binding.
Channel after the Teflon strip has been removed.
Installing the purfling segments.
JJ
Re: Cocobolo O’M
Post by John Parchem » Thu Dec 05, 2019 2:19 pm
That purfling is way cool! I love the look.
John J
Re: Cocobolo O’M
Post by John J » Thu Jan 16, 2020 1:46 pm
Thanks John.
Slow progress with the holidays, but I have done a bit. The neck attachment is similar to the Gore/Gilet bolt on. This differs in a couple of ways. The heel profile has to be at its final shape and sanded to a nearly finish state. The tenon is tapered from just underneath the top bolt hole to the bottom of the tenon. And since the fingerboard extension is not bolted down, but is free floating, it too has a slight taper to the underside.
Then I bolt it up and check for angle and center. Then I’ll use a new scalpel blade to scribe the heel outline on the body.
Then I oh so carefully rout out the heel pocket, finishing with a sharp chisel. I then deepen the neck pocket slightly from just below the top bolt hole to the bottom of the heel. This allows for movement.
A final fitting and I can finish shape the neck.
JJ
Re: Cocobolo O’M
Post by John Parchem » Thu Jan 16, 2020 2:17 pm
Wow, That work looks really good. I like the neck design. Look forward to seeing this guitar complete.
