Dented frets
Re: Dented frets
Post by peter havriluk » Sun Oct 28, 2018 8:06 pm
John's advice to replace the obviously damaged frets, sand level, and inspect the results impresses me as the best thing to try first. It certainly seems to me to be the least invasive solution and may well solve the whole problem with the least amount of work. No use sanding down and crowning a perfectly good fret.
Re: Dented frets
Post by Herman » Mon Oct 29, 2018 10:27 am
Paul, If it conceirns a few frets, I would go with the replacement of those frets.
If it is all up from 1 to the 7th fret I would go with leveling.
About the leveler: You can use any square pipe 1"wide with sticking sandpaper to do the job.
FWIW: I started with the expensive bought tools and now working with the home made levelers. Ha!
Paul C
Re: Dented frets
Post by Paul C » Thu Nov 01, 2018 12:20 pm
Thank all you guys for your input. I'm gonna try and remove the bad ones. Let y'all know how it goes.
