Plate joining question
Re: Plate joining question
Just like the factories (who have big time warranty concerns) I use a properly set up power joiner -- mines a 6" Delta/Craftsman, takes a about 30 seconds for two passes. And no Martin and others do not use some special bowed or angled cut -- I have talked to plant engineers and they dispelled this myth.
Thank you very much for all of the replies.
Do you think the router table idea will work as well as a jointer?
"Do you think the router table idea will work as well as a jointer?"
Maybe -- but likely not, depends on design, vertical or horizontal? Ease of in/out fence adjustments, vibration control, etc.
ken cierp wrote:"Do you think the router table idea will work as well as a jointer?"
On a router table with a straight cut bit.
You would be making a shiity jointer, it may work OK but at times you may get a bit of tear out especially on figured wood. Take a note of the differences between a good jointer and a router table with a straight bit.
Duly noted. Thanks!John Parchem wrote:You would be making a shiity jointer, it may work OK but at times you may get a bit of tear out especially on figured wood. Take a note of the differences between a good jointer and a router table with a straight bit.
Today I made this thread moot. I purchased a Veritas Low Angle Jack Plane with the PM-V11 blade. NTD coming soon!
