Dave, I've looked over Ken's photos but I'm not sure just what the modifications were made the the nibblers. And BTW it appears that the nibbler is out of production now. I'm wondering you might be able to share what the modification consists of?
And might you have the information on where you purchased the wheels for the Dremel for doing the end radius on the frets, please?
An experiment that worked well
Re: An experiment that worked well
"Good enough, never is"
Kim Hillard
Burdickville, Michigan
Kim Hillard
Once you have the stock nibbler in hand the mod is obvious -- you need to grind a groove to accept the wire. Shown in image 3
Kim, got them on ebay:
- Capture.JPG (26.41 KiB) Viewed 3376 times
Dave and Ken. Thank you both.
Kim Hillard
Kim Hillard
Here is where I stol.....I mean, got the basic idea:
https://youtu.be/moxUw3Ke2Q0?t=5s
And if you want to build a simple jig for nipping fret ends, he has this (I have not had the problems he has had with the fret nippers, above)
https://youtu.be/fvdnpilpdVc
