On the plan it looks like there are little braces to the end of the bridgeplate. The x-braces don't cover the end of the bridge. Is that so, or do I need new glasses?
Stahl Style 6 Build
Re: Stahl Style 6 Build
Very striking!
Not a criticism --- but I offer this as a building tip. When using slab or riff sawn material, the symmetrical appearance can be improved by aligning and adjusting the grain convergence points rather than simply matching the plate length. A standard 22" plate blank usually has plenty of length to accommodate the offset.
Ken- thanks. The light colored convergence could have lined up better. I also thin the back strip seems to actually compound the issue.
Herman- here's a clearer picture of the plan. The bridge will cross the x brace. What's different is that the bridge plate is skewed for whatever reason.
And just as an aside - it's much easier to do the rosette before you glue the x braces in ;-)
- IMG_6319.JPG (120.93 KiB) Viewed 1328 times
JJ
Ok, now I see. Strange way to put the bridgeplate angled under the bridge.
herman
herman
[quote="Herman"]Good clean work, John. Nice wood indeed. Be careful on sanding the Pau Ferro. I, and others too, got allergic to the wood dust.
Herman - was the allergic reaction immediate? I haven't noticed anything. I used my drum sander to thickness back and sides.
JJ
John, I have been close to picking up some Pao Ferro a few times on Ebay and am quite interested in it. I would love to here more on your thoughts about it.
According to Wood Data Base: Although severe reactions are quite uncommon, Pau Ferro has been reported as a sensitizer. Usually most common reactions simply include eye and skin irritation. Anecdotal evidence suggests that there is a high rate of reaction among woodworkers, and the wood contains the very same sensitizing substances as those found in rosewoods (Dalbergia genus).
http://www.wood-database.com/pau-ferro/
Jim.
Jim.
Jim, I haven't noticed anything as of yet. I have congestion type allergies that have existed long before I started working with woods. I have not noticed any eye or skin reactions to Pau Ferro or Indian Rosewood or Brazilian RW. So far it seems to work well, bends easily and sands easier than Brazilian (doesn't seem to gum up the sandpaper). It's certainly beautiful.
JJ
