3 and 4 piece tops for classical and steel string guitars
Re: 3 and 4 piece tops for classical and steel string guitar
Looks really good who would ever know
If you wet it with naphta, you can probable see if there is runout, as Ken points out.
I just wanted to share and this goes along with the redwood that I got for these tops. Some of the boards are less quartered, not as desireable for tops, so I thought I might be able to use some for solid linings. I cuts 6 strips, 5/8" tall by 1/8" thick and put them in the bender the other night. Taped them together in 3's.
They came out great. One did break at the waist, but the others are fine. I put too much pressure on the waist before the heat was up, and I heard the crack.
Anyway, I will use them on the next guitar and see how it goes. They may be a bit soft, but will be plenty strong two glued to each other.
I have enough for a lot of guitars, and it comes out about one 10th the cost to buy pre-made kerfed linings. I can do 6 guitars linings for $10.
- 20161214_173010.jpg (201.53 KiB) Viewed 998 times
