That would not hurt. I'd suggest making your bracing a little more triangular (thin at the top) you don't loose much strength but that will reduce the weight and increase response -- just a thought.
Not the shoulder brace.
L-0 and behold
Re: L-0 and behold
Re: L-0 and behold
I went with the popsicle brace. Box is closed. Bindings next along with the neck. I reall like the shape of this one, at least visually.
- image.jpeg (77.46 KiB) Viewed 1147 times
- image.jpeg (87.45 KiB) Viewed 1147 times
- image.jpeg (139.28 KiB) Viewed 1147 times
- image.jpeg (165.93 KiB) Viewed 1147 times
- image.jpeg (121.08 KiB) Viewed 1147 times
JJ
Re: L-0 and behold
Looking fantastic!
Re: L-0 and behold
Beautiful.
Re: L-0 and behold
Some more progress. Bound the fretboard and did the inlays. I made the diamonds from padauk cut so the end grain shows. Side markers are from some padauk "toothpicks" I made. Neck carved and tenon created/bolt on style. Head plate and backstrap on. Bridge created from a laminate of Brazilian rosewood and padauk. Test fitted tonight not too bad. Need to do some tweaking.
- image.jpeg (93.3 KiB) Viewed 706 times
- image.jpeg (108.85 KiB) Viewed 706 times
- image.jpeg (117.75 KiB) Viewed 706 times
- image.jpeg (114.29 KiB) Viewed 706 times
- image.jpeg (169.44 KiB) Viewed 706 times
- image.jpeg (176.65 KiB) Viewed 706 times
- image.jpeg (164.3 KiB) Viewed 706 times
JJ
Re: L-0 and behold
Nice work on the back strap and the inlays, the guitar is really coming together and looking great.
