Cocobolo 00 12 fret steel string
John J
Re: Cocobolo 00 12 fret steel string
Post by John J » Sat Nov 07, 2015 9:01 pm
I'm very interested in how it will sound with fewer braces. Also John, why so thick on the tail block?
JJ
Post by John Parchem » Sat Nov 07, 2015 9:22 pm
John J wrote:I'm very interested in how it will sound with fewer braces. Also John, why so thick on the tail block?
The tail block is thicker than it need be. it is 3/4 but 1/2" would be fine. I had some 3/4"birch plywood awhile back when I made a few blocks. I figured it would not hurt anything.
Post by Kevin in California » Sat Nov 07, 2015 10:56 pm
The one time I used Cocobolo on my #3 Dreadnaught, it was HEAVY! But it does have a nice sound.
I've never played on of these small body guitars. I'll have to make one some day.
Post by Herman » Mon Nov 09, 2015 6:33 am
John,
What size braces did you make, 6 or 8 mm?
Post by John Parchem » Mon Nov 09, 2015 12:20 pm
Herman wrote:John,
For width 6mm for the top and 10 mm for the back and UTB.
Post by John Parchem » Fri Nov 20, 2015 2:24 am
I closed the box and have the bindings on. This is one of a number of guitars I have built for family members. I have 24 nieces and nephews so I keep them relatively simple. So I have curly maple bindings on this guitars with no purflings. A thin black purfling would have been good for the top but too late now.
I think the only note of interest, and I hesitate to bring it up as it is so obvious but I have missed it on all my other guitars: I use a scarf joint to join the bindings, this time I put the binding down where the scarf joint made a pocket for the second binding to fit in. I had always done it so the second binding went on top of the first. But that is so prone to slipping. Here is a picture that will show it better.
With the first glued on I can push the second binding into the scarf joint with some pressure before taping making a really tight joint. I felt like an idiot a luthier showed me this.
Here are some pictures taken through the process.
Just for fun I used the gobar deck to glue on the top, also I glued on the top first a reverse of my normal order. I wanted to see what a top spectrum looked like before the back was glued on
I just used clamps for the back.
I have an LMI neck for this guitar. I want to see if I can get it out by christmas
I leveled the sides by marking them with a pencil and using my drill handheld drum sander. One really needs to be careful with this it removes wood quickly
I bent some bindings in my bending jig and set my router and routed the channels
I for the most part just taped in the bindings. I did make sure that the waist was tight
I am ready for the neck. But I forgot to order the inlays and I want to inlay the fret board off the neck. Oh well I will still start getting the neck ready tomorrow.
Post by Herman » Fri Nov 20, 2015 1:58 pm
beauty John
