Mt latest and first 00
Jay McClellan
Re: Mt latest and first 00
Post by Jay McClellan » Thu Mar 19, 2015 2:41 pm
Tim Benware wrote:It has a laminate patch I made up glued to the inside. Those fingers are really pretty stout.
Ah, nice. You can't tell it's laminated from the outside, at least not from the picture. I might try something similar in my next build. I think it might look good (or maybe not?) to use a black/white/black veneer laminate to match the purfling I use.
Jay McClellan
http://BrainRight.com
Post by Tim Benware » Thu Mar 19, 2015 3:14 pm
It's a B/W laminate approx .055" thick.
DSCN0511 (640x480).jpg (132.1 KiB) Viewed 1128 times
Post by Herman » Fri Mar 20, 2015 2:33 pm
Niiiiice!!! I'm a fan of soundports for some time. Around here I see more and more of them. Next to the advantages soundwise, it gives an extra opportunity to stand out artisticly. You do well here.
Post by John Parchem » Fri Mar 20, 2015 3:26 pm
Very nice, I have not been brave enough to go beyond an oval
Post by Tim Benware » Sat Mar 21, 2015 12:04 am
johnparchem wrote:Very nice, I have not been brave enough to go beyond an oval
Go for it. It really isn't much different.
Jay McClellan
Post by Jay McClellan » Sat Mar 21, 2015 10:48 am
How do you determine the size of the sound port? Is there a guideline to follow in terms of sound port area vs. body volume? Or do you calculate the size using the LAR algorithm?
(Looks About Right)
Jay McClellan
Post by Tim Benware » Sat Mar 21, 2015 3:35 pm
I don't get too technical. In theory the box is nothing more than an air pump, similar to a speaker enclosure and the same sound principles apply. I try to keep it in the 1.5" to 2" range centered between the kerfing so that it LAR:) This one is about 2" long and 1.75" at it widest.
